JohnHThomasIII
Mar 11, 2018Follower
Need a way to restrict access to apps on specific devices (using Orbi RBR50)
Specifics: Orbi RBR50, firmware v2.0.1.4, Windows 10 I'm looking for a way to access devices connected to my network and specifically target those devices so that I can restrict access to certai...
DarrenM
Mar 12, 2018Sr. NETGEAR Moderator
You may want to look at disney circle as it is a parental program that is install on Orbi with firwmare version 2.1 or higher the paid version has some in depth controls of devices.
https://www.netgear.com/landings/circle/default.aspx
DarrenM
