zhangy
Jun 30, 2018Aspirant
Need able to assign device stay 5ghz
I just purchased the orbi yesterday. Like the idea of merge 2 band into one name. But my lg tv sometime switch to 2.4ghz and makes 4k streamming not working. Some device like google home mini next to ...
Jul 01, 2018Guru - Experienced User
Not really possible with Orbi. The system auto assigns where devices get connected automatically based on signal, noise, range and device support. There maybe factors causeing your TV to change frequencies like interferences and distance.
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and other unused channels on 5Ghz.
Diable MIMO, Daisy Chain and Fast Roaming.
Whats the distances between the router and satellites.
Whats the distances between the router, satellite and TV?
- zhangyJul 01, 2018Aspirant
i guess it's because google home mini is always connected to wifi and the first time when it connect, it's lucky and connected to 5GHz. Even thought i don't think google home need a 5G at all.
while my tv is turn off and on everyday so when it's unlucky it's connected to 2.4GHz and stick with it.
really need a feature to assign manually so device could be useful when they need 5Ghz.
2.4G for 4k streamming is disaster.
- FURRYe38Jul 02, 2018Guru - Experienced User
Be sure your TV supports 5Ghz as well...check with the TVs Mfr for help and information...
- mith_itJul 02, 2018LuminaryThis is purely anecdotal, but I noticed some of my devices occasionally find themselves on a 2.4Ghz network instead of 5Ghz even if I'd have a closer satellite available.
It would be great if there was a way to "incentivize" clients to switch to the best and closest 5Ghz and use 2.4Ghz only when no better option exists.
Personal opinion is that Orbi is better than a regular extender, but isn't a refined system at this point.- loomis1975Jul 02, 2018LuminaryRight now, I think one of the only things you can do for this situation is adjust the 2.4ghz transmit power level down 1 or 2 steps. It's not a cure all, but it might help. I too wish you could reserve which band to use, just like you can reserve ip address.
