zhangy
Jun 30, 2018Aspirant
Need able to assign device stay 5ghz
I just purchased the orbi yesterday. Like the idea of merge 2 band into one name. But my lg tv sometime switch to 2.4ghz and makes 4k streamming not working. Some device like google home mini next to ...
zhangy
Jul 01, 2018Aspirant
i guess it's because google home mini is always connected to wifi and the first time when it connect, it's lucky and connected to 5GHz. Even thought i don't think google home need a 5G at all.
while my tv is turn off and on everyday so when it's unlucky it's connected to 2.4GHz and stick with it.
really need a feature to assign manually so device could be useful when they need 5Ghz.
2.4G for 4k streamming is disaster.
Jul 02, 2018Guru - Experienced User
Any other wifi neighbors near by? If so, how many?
What channels are you using? Try manual channels 1, 6 or 11 on 2.4Ghz and other unused channels on 5Ghz.
Diable MIMO, Daisy Chain and Fast Roaming.
Whats the distances between the router and satellites.
Whats the distances between the router, satellite and TV?
Be sure your TV supports 5Ghz as well...check with the TVs Mfr for help and information...
