sethm1
Jun 29, 2020Guide
Need another ethernet port
Rbk50. This one only has 3 ethernet ports - I need a fourth. I preordered the Wyze outdoor camera which comes with its own wifi base station. would I be able to use a splitter such as this.... ...
- Jun 30, 2020
Wouldn't be overkill, switches are inexpensive and easy to setup. Turn ON and plug in play. Your up and running. You can plug any wired device into the RBS.
sethm1 wrote:Thanks. 5 port is overkill. But that wont degrade speed correct.
The satellite has ports right? So instead of the switch, I should be able to plug in the wyze base station into the orbi sattelite??
sethm1
Jun 29, 2020Guide
Jun 30, 2020Guru - Experienced User
