GWild
Apr 05, 2019Guide
Need detailed IP traffic monitoring
The Orbi has a web connect to monitor traffic. It is 1) hard to get to; 2) logs out almost immediately; 3) requires manual presses to keep updated.
Not very useful for just watching activity. ...
Apr 06, 2019Guru - Experienced User
Would be hard to do for a cable modem/router. IF you had a separated modem and router, then you could put something in between the modem and router to capture data. Not really possible with a all in one system.
- GWildApr 07, 2019Guide
Not looking for traffic detail by application: I am looking for total BYTES SENT / RECEIVED.
I'd be happy with this display: 458MB Down / 89MB Up.
But I want something light weight that can query the router without all the trouble of logging in through the ORBI web UI - waiting for everything to settle (why does it take 30 seconds to log in? Another 30 seconds to get to the Advanced tab, and another 30 seconds to get to the Traffic page? I'm exaggerating a bit, but the time it takes to get to these pages is way too long for a router. I've worked with real routers that do better over remote links half way around the world.
- FURRYe38Apr 07, 2019Guru - Experienced User
Well again, these are home class routers. Not much call for more granular or advanced features for the average home user. AGain, this is a gateway modem router, not a stand alone router.
You might see if you can capture something down at the telnet level if there is anything like this.
Otherwise your stuck with what NG provides.
Good Luck,
