jjnell61
Nov 08, 2020Follower
need help connecting to my Orbi rbr20 with FIOS router
I'm having an issue connecting my orbi to the FIOS router. Everything that I tried it tells me that it has issues connecting with the ORBI92.
Nov 09, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
