tklimek
Dec 05, 2023Follower
Need help enabling peer to peer wifi communication on a Orbi RBR50 tri -band.
Sorry I don't have a lot of information to share. I have a friend with ALS who needs help with his router config and I am trying to help him from long distance. He needs wifi device to device communication within his home. The term he used is disable AP isolation. I can do this on my Night Hawk by check a box to "Allow guests to see each other" Does anyone know how to do this on a Orbi RBR50 tri -band?
1 Reply
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Set up a guest WiFi networkFor more advice on that device, try the appropriate section of this community:
Orbi Mesh Systems - NETGEAR Communities
