m_chop's avatar
m_chop
Follower
Nov 13, 2018
Need help for RBR50 expansion options
I have The RBK50 which is a kit that containing one RBR50 router and one RBS50 satellite. Can I:
  1. Expand this system with an add on?
  2. If so, what is the model and number I need to buy to add to this mesh?
Thanks
MC
  • Can add up to 3 officially. Others reporting having 6 satellites.
    RBS50 satellites is what you would need.
  • Any of the RBS or RBW models should work. Basically, anything under "satellites" on this page (also pictured below).
