5_olivers
May 15, 2018Guide
Need help isolating packet loss
I have an Orbi RBK50 with 2 satellites connected via ethernet backhaul and 300 mbps internet connection. I have an HDHomerun Connect Quatro attached to the router via ethernet. The HD box is used to ...
- May 20, 2018
Thanks for the update.
You might just have an Orbi with bad hardware. Swapping it out with another unit at Costco might solve the issue.
Let us know if you find a solution that works for you.
5_olivers
May 20, 2018Guide
I ran all three wired AFTV sticks on the d-link switch with WAN connected via LAN port from the Orbi. It ran solid for over 5 hours.
I tried to replicate the set-up as closely as possible on the Orbi, but since it only has 3 LAN ports, I could only run two wired devices and the HD box. All other devices were disconnected, including wifi.
It ran fine for about an hour, then I tried to add wifi so I could stream another AFTV device, connect the d-link switch so I could connect a computer, then things started to go south. I had to reboot the router, which amazingly takes FOREVER to establish the internet conncection.
After multiple attempts at restarting the cable modem, restarting the router, reconnecting the satellites, I have given up. This is way too frustrating and time consuming. Luckily, I purchased my Orbi at Costco and they have a great return policy. It is going back today.
Thanks very much for your help along the way. I am very confident now that the HD box works and my network was running fine prior to switching to Orbi. While I may not have identified the exact issue with the Orbi system, I am pretty confident it is at the root of my issues.
It may work for others who have the time and patience to work with it, great for them, but I have never owned a system that requires so much care and attention ... don't have the time for it when there are other solutions out there that appear to be more reliable.
st_shaw
May 20, 2018Master
