Eric52's avatar
Eric52
Follower
Jun 21, 2018
Need help on "bridge mode/access point" configuration
A music server I just purchased requires a wired connection to my LAN. Also, the user manual requires the following on the LAN: "Wireless Access Point or a Wireless router set to a "bridge mode/acces...
  • FURRYe38's avatar
    Jun 21, 2018
    The default initial setup will be for Router Mode. You'll need to go into Advanced tab/Advanced settings/Router/AP mode. There you will see two modes, select AP mode. The system will reboot.
