BleedingCash
Jun 25, 2019Tutor
Need help on updating Orbi RBR40/RBW30 firmwares
Hi, I need some advice on what to do. I have the RBK33 kit, which includes the RBR40 base and the RBW30 satellites. When I first installed them, I manually updated them to firwares 2.2.1.210 fo...
- Jun 25, 2019
I just wanted to report back. Everything went well. Steps taken were as follows (to help myself in the future, if needed):
- Disconnected the router base from my modem so that it had no internet so that the router base wouldn't automatically update itself while I'm trying to update the satellites first.
- Over wifi, logged in to the router and manually downgraded the firmware of the router directly from 2.3.1.44 to 2.2.1.210.
- Had to unplug and replug in the satellites to their electrical outlets to get them to change from "Waiting for connection" to "No internet" so that I could update their firmwares.
- Updated the firmwares of the satellites (one at a time for my own feeling of comfort) directly from 2.2.1.204 to 2.3.0.4.
- Updated the firmware of the router base directly from 2.2.1.210 to 2.3.1.58.
- Plugged the router base back into the modem.
Internet is up and running and statuses are good on all 3 devices.
Thanks for the help, Furry!
BleedingCash
Jun 25, 2019Tutor
Hi Furry,
Thanks. Do I have to downgrade in steps, or can I just jump all the way back down to 2.2.1.210 for the base? Same sort of question for the upgrades...when I go up, can I skip all firmware levels and go straight to the latest, or do I have to do them in steps?
Thanks!
Jun 25, 2019Guru - Experienced User
You can go to v210 I believe...
You can go directly to v58 on the RBWs first. For the RBR, you may need v212 first, then v58.
- BleedingCashJun 25, 2019Tutor
Hi Furry,
Okay. Thanks.
- FURRYe38Jun 25, 2019Guru - Experienced User
Hope it works....Good Luck.
FURRYe38 wrote:Hope it works....Good Luck.
Thanks. Last question. Should I disconnect the base from my modem during the manual downgrade/upgrade process to make sure that the base doesn't try to update itself automatically before I finish manually upgrading the satellites, or will this totally crash the manual firmware update process?
Thanks!
