remixsan
Oct 14, 2018Aspirant
Need help port forwarding NAT Type
Hey, hello,
I've been struggling with port forwarding and enabling UPnP. Since the new game Black Ops 4 came out I have not been able to play with my friends thanks to my NAT Type being Strict instead of Moderate or Open :-(((
So I've been trying to make it open, by forwarding port 3074 and enabling UPnP. I forwarded the 3074 port by going into Advanced => Advanced Setup => Port forwarding/ Port Triggering and adding this rule:
Where the internal IP address is my computer. I've made this IP Static from IPv4 settings in Windows 10.
Heres my UPnP enabled:
I'm running one Orbi Router and two satellites and I'm connected to the Satellite 1 with ethernet. Has this issue something with me being connected to the Satellite instead of the Router it self or what's up? I need help!
Thanks!
- remixsanAspirant
I can now see with UPnP enabled (and Black Ops 4 running and online to services) I see the ports in the UPnP Portmap Table. I don't know if this is a step in the right direction - it's still Strict though :catsad::catsad:
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?Remove any port forwarding configurations you have set up as they are not needed. Just enable uPnP is all that you need.
