woodmont
Jan 07, 2023Follower
need help with RBS 10 Orbi AC1200 mesh wifi
For one thing, their site won't even let me change network names and such anymore. They forced me to set up a new network name and now my first network does not seem to work anymore. Before they made...
KevinLiT
Jan 09, 2023NETGEAR Moderator
Hello woodmont,
Welcome to the NETGEAR Community!
I understand that you are having issues with the Wi-FI on your RBR10. You mentioned that you are not able to change the name of the network SSID and that you are not able to use your Orbi mesh networks Wi-Fi.
Please plug your router into your PC then do the following:
Go to Orbilogin.com> ADVANCED> Wireless Settings> Check the following options> Enable SSID Broadcast, Enable Wireless Router Radio, Enable 20/40 MHz Coexistence >Then Select APPLY.
Please let me know if this solution solves your issue!
Best,
Kevin
Community Team
