SSM587
Sep 12, 2020Aspirant
Need help with Teardown/Putting Orbi back together
One of my satellites (RBs50v2) dropped on the floor while i was moving stuff around, and the top cover (near the LED ring) came out. The casing is also open, and the transparent plastic ring thingy in...
SSM587
Thanks. But doesn’t look like there are any screws (took out all feet, nothing under them). Seems the entire casing is just held together with plastic clips.
The satellite itself is functional. I have wrapped it up a bit in cling-film to avoid getting dust and other stuff inside.
Will try and reach out to a service center locally.
Sep 12, 2020Guru - Experienced User
Hope they can help. Let us know how it goes.
