SSM587
Sep 12, 2020Aspirant
Need help with Teardown/Putting Orbi back together
One of my satellites (RBs50v2) dropped on the floor while i was moving stuff around, and the top cover (near the LED ring) came out. The casing is also open, and the transparent plastic ring thingy in...
Mooose
Nov 09, 2020Luminary
Would you mind posting some photos when you have it open? I have something that isn't secured correctly in my router, it rattles when I shake it. I am assuming it is an antenna, but I'd like to see what it looks like before I attempt to take it apart.
- gjacknowNov 09, 2020Guide
There are plenty of photos out there...
https://fccid.io/PY316200341/Internal-Photos/Internal-Photos-rev-3108554
