Mattyl22l
Aug 28, 2018Aspirant
Need Help
A while back I purchased an Orbi system. The RBK50 [RBR50 with 1 satellite] and a NETGEAR CM700 Cable Modem.
Ever since the begging of using these products I get a lot of inconsistent speed...
Mattyl22l
Aug 30, 2018Aspirant
Ok, I checked my Xbox and it says it's on Port 3074.
I then connected the Xbox straight to the Modem/CM700 and it says STRICT, uPnP not available.
Aug 30, 2018Guru - Experienced User
There either is a problem at the modem which I don't believe is the main issue, I think the problem is with your xbox. What model is the xbox? X or original? S?
Try both consoles at the modem directly?
When connected to the modem directly, you should see OPEN.
You could contact the ISP and see if they notice anything while connected directly to the modem.
- Mattyl22lAug 30, 2018Aspirant
#1 Console is an Xbox One S
#2 Console is an Xbox One original
Both are wired directly to Router
Both consoles display STRICT NAT when connected to router
Both consoles also display STRICT NAT when connected directly to Modem
PS: I now have replaced all wired Ethernets with the suggested CAT7 and Coax Cable with RG6. I also took a look at the link where you describe your friends setup you did, also made those change in my Router.
