Mattyl22l
Aug 28, 2018Aspirant
Need Help
A while back I purchased an Orbi system. The RBK50 [RBR50 with 1 satellite] and a NETGEAR CM700 Cable Modem.
Ever since the begging of using these products I get a lot of inconsistent speed...
Mattyl22l
Sep 03, 2018Aspirant
Hey, I've been keeping an eye on it for the past couple days and what I've obsurved is most of the time the morning up until 3pm my connetion is almost flawless, a fairly consistent 15 ping/ms in most matches at around 40mb/s download. But it seems around 3pm I noticed it change instintly back to frequent lag spikes where it goes from 50 ping/ms and 30mb/s download to as bad as 150-200 ping/ms at 8mb/s back and forth (almost unplayable on Xbox and where it sometimes lags me out of matches).
Do you think the ISP service isn't strong enough?
Sep 03, 2018Guru - Experienced User
Something to contact the ISP about and let them know that all is good up to around 3PM. They should be able to see changes on there side during this time frame...
