TEC5154
Aug 18, 2018Follower
Need some help with Orbi and Ring Doorbell 2
Hi everyone. I know this subject has been talked about on different posts in the forum but I'm trying to post a new one because I don't know if there has been a clear cut solution. Like many others...
Aug 18, 2018Guru - Experienced User
- orbiguyDec 01, 2018InitiateAfter much troubleshooting, what worked best for me is:
2.4 GHz - Channel 1
Disable 20/40 Coexistence
Thank you all in this forum.- PinOZMar 01, 2019Aspirant
That ties in with advice in another thread, but MUST the Orbi stay on a channel below 11 all the time, or can I revert to AUTO channel after first connection.
- FURRYe38Mar 01, 2019Guru - Experienced User
Something to try out and let us know if the Doorbell device works on channel 11. If it doesn't, then this is a problem with the device and the Mfr of this device should review and ensure there devices work on ALL supported 2.4Ghz channels.
