mjcj421
Jun 24, 2020Follower
need the network security code
where do i find the security network code
schumaku
Jun 24, 2020Guru - Experienced User
In a new install (or factory reset) Orbi device, the default network name and the network security key is printed on a banderole and below of your actual Orbi router device.
CrimpOn
schumaku wrote:In a new install (or factory reset) Orbi device, the default network name and the network security key is printed on a banderole and below of your actual Orbi router device.
I think "autocorrect" got ahold of this. My Orbi came with a clear plastic sleeve around the top with the WiFi name (SSID) and password on it. i.e. "banderole". (My "used" Orbi I purchased off eBay did not.) The information is also printed on the product label sticker on the bottom.
- schumakuJun 24, 2020Guru - Experienced User
CrimpOn No spell checker, just typed some French before ... https://en.wikipedia.org/wiki/Banderole ... clear plastic sleeve is of course the better descripton. Thank you for the heads up!
