DirtyGoose
Jan 22, 2021Follower
need to return orbi model RBK20W.
i was connected to wifi but could not connect to mobile app or routerlogin.. after talking to netgear service associate found out due to our modem having a router also we could not connect to mobile...
Jan 22, 2021Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- vajimJan 22, 2021Master
if your modem is actually a modem/router combo you may try this:
