skerit
Apr 21, 2020Aspirant
Need to setup portforward for port 443 even though the target is in the DMZ
I'm unable to connect to port 443 on my DMZ host. Port 22, port 80, port 2999, ... everything works EXCEPT port 443. When I perform an external port check (with `nc -zvw3 280.266.258.260 443` fo...
Apr 21, 2020Guru - Experienced User
If the target device is in the DMZ then you don't need to PF.
skerit
Euhm... That's exactly the problem I'm describing here. I *have* to configure a portforward rule or it doesn't work. It's even in the title :/
- FURRYe38Apr 21, 2020Guru - Experienced User
When in the DMZ all ports are made available to the target device while in the DMZ. Thus no PF is needed.
http://www.dslreports.com/shownews/Networking-101-The-DMZ-137550
- skeritApr 21, 2020Aspirant
Yes, I know what a DMZ is. That's the problem here. When I don't set up the port forward rule, port 443 does not reach the target host. So I'm saying something's broken in the DMZ implementation of this device.
What happens if you remove the target device from the DMZ, disable uPnP then configure the PF rules you need? This works?
