rsovitzky's avatar
rsovitzky
Need to transfer registration to associate
I need to transfer the registration of my Orbi to my associate. Based on the purchase date, I do not have the option to contact support directly. How can I accomplish the transfer? Thanks, Rick
  • If you contact Netgear they will help you with the transfer.
    Or you can go to your account, if you registered your Orbi, and remove it from your account.
    • rsovitzky's avatar
      rsovitzky
      Thanks Mstrbig , however it is not clear how I contact Netgear and I do not see an option to remove the products from my account.
      • Mstrbig's avatar
        Mstrbig
        Master
        You can call their toll free number. They will help you as it is not a support issue. I've done it many times.
