alokeprasad
Jan 06, 2024Mentor
Neither the Orbi, nor my NAS is reachable over WiFi. They are over Ethernet
Starting a new discussion thread on this problem. The web interface to the Orbi (192.168.1.1/index.htm) or my NAS (192.168.1.11:8080/cgi-bin/) are not reachable when my MacBook is on WiFi. The we...
- Jan 06, 2024
My experience with the Netgear RBR50 (I have one) is that 'wired' devices are not treated differently from 'WiFi' devices. They both use DHCP to receive IP assignments, subnet masks, gateway IPs and DNS IPs. Every device connected to the primary WiFi SSID can communicate with every other device. Devices connected to the Guest WiFi SSID may be restricted to internet access only (not able to communicate with other devices on the network).
Sometimes it is helpful to validate assumptions. When connected to the network with an Ethernet cable, it is obvious which network the device is part of. How do we establish that the MacBook is connected to the Orbi WiFi?
- Does it appear in the web interface Attached Devices? (or the Orbi 'app' Device Manager)
- Does the WiFi connection have an IP address in the 192.168.1.x subnet?
- Does the WiFi connection display the primary WiFi SSID or the Guest SSID?
CrimpOn
Jan 06, 2024Guru - Experienced User
- schumakuJan 07, 2024Guru - Experienced User
In case there is a wired backhaul connecting RBR50 and RBS50 likely (not very likely, it's still a bridging environment). In case the RBR50 does also direct connect the docking station and the NAS it is. In case the RBS are on a wireless backhaul it isn't that obvious.
- alokeprasadJan 07, 2024Mentor
Thank you all for very good ideas on tracking this down.
CrimpOn, I reach across the interwebs and shake your hand for winning the Sherlock Holmes medal 😀
My (new and first) Macbook was connecting to the guest network by default!!!
When setting up my new MacBook, I entered the credentials for the "regular" non-guest SSID. However, when signing on yto my AppleID, as with all Apple devices in the walled garden, the Macbook got the credentials for all networks from my other devices like iPhone and iPad. For some reason, it selected the guest network to connect to after that. This did not affect the wired connection behavior.
I switched it to the non-Guest network and bingo! Problem fixed.This was an interesting journey.. first with selective networking, wired vs Wifi behavior, encrypted DNS behavior, then finally, Guest vs non-Guest WiFi connections. Thank you all for staying with me through this.
Moral: there is no such thing as "set it and forget it" when it comes to IT!! There is a curveball around every corner (mixing metaphors).
Aloke
