AlankirshAspirantMay 16, 2018NEO AnkuooIs there a way to get the Ankuoo NEO switch hooked up to the Orbi WiFi system?
FURRYe38Guru - Experienced UserMay 16, 2018You might contact the Mfr of that device and ask for help and information regarding set up for it.
AlankirshAspirant to FURRYe38May 16, 2018Is it possible to just get the 2.4g so that I can sink with my NEO Ankuoo light switches. With the dual signals I’m putting out from the Orbi, the switches are not compatible.AlankirshAspirant to FURRYe38May 16, 2018Thank you, needs to sink 2.4 signal.
