Alankirsh
May 16, 2018Aspirant
NEO Ankuoo
Is there a way to get the Ankuoo NEO switch hooked up to the Orbi WiFi system?
May 16, 2018Guru - Experienced User
You might contact the Mfr of that device and ask for help and information regarding set up for it.
Alankirsh
Is it possible to just get the 2.4g so that I can sink with my NEO Ankuoo light switches. With the dual signals I’m putting out from the Orbi, the switches are not compatible.
