Alankirsh
May 16, 2018Aspirant
NEO Ankuoo
Is there a way to get the Ankuoo NEO switch hooked up to the Orbi WiFi system?
May 18, 2018Guru - Experienced User
There is a thread on here that others have posted about splitting the one SSID name between 2.4Ghz and 5Ghz. Something you can try, however is not supported by NG. Orbi system are designed to run with smart connect using a on SSID name and pw for both radios.
