Hamstar
Sep 17, 2018Guide
Nest camera drops still frequent on Orbi RB50 firmware v2.1.4.16
I have had my Orbi system for about 3 months, purchased from Costco in June. 1 day after installing the system, firmware was upgraded to v2.1.4.16. I have google fiber 1000 and enjoy the speed. Me o...
- May 24, 2019
My Nest was frequently going offline. I changed my settings on my Orbi to match Kickworms settings and I have not had a drop in over a week. Seems resolved now. Here are the settings from Kickworms post:
- 20/40 MHz Coexistence is enabled (2.4GHz)
- WMM is enabled (both 2.4GHz and 5GHz)
- CTS/RTS Threshold is 2347 (both 2.4GHz and 5GHz)
- Preamble Mode is Automatic (both 2.4GHz and 5GHz)
- Transmit Power is 100% (both 2.4GHz and 5GHz)
- Daisy-Chain Topology is DISABLED
- Beamforming is enabled
- MU-MIMO is enabled
- Fast Roaming is DISABLED
- 2.4GHz channel is set to Auto
- 5GHz channel is set to 48
- Security Option is set to only WPA2-PSK
Sep 17, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and. Save settings and reboot the router and satellite(s).
Try this and see:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
I changed the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
Hamstar wrote:
I have had my Orbi system for about 3 months, purchased from Costco in June. 1 day after installing the system, firmware was upgraded to v2.1.4.16. I have google fiber 1000 and enjoy the speed. Me only issue that I experience is frequent drops from my 3 nest cams (2 outdoor and 1 indoor). I’ve tracked the drops and worked with Nest support.
When I have been able to get to a tech specialist the say that it is low upload speed. I understand there are a lot of variables and have set settings in the Orbi to optimize it from talking directly with Orbi support, but I can’t seem to go longer than 2-3 days without a drop.
It doesn’t matter if we are watching tv or streaming from Netflix, Apple, Amazon, or when no one is home or we are sleeping. I have EXCELLENT bandwidth at each camera. The outdoor cameras seem to stick to the nearest satellite - front or rear on 2nd floor each no more than 15 feet from the satellite. The indoor camera is in the same room as the router about 10-15 feet away.
All 3 cameras connect at 5GHz. The Orbi app on my iPhone shows full bars on the Wifi icon. Interested enough the indoor camera connected to the router which rarely drops reports the link rate typically in the 54-80 Mbps range while the outdoor cameras connected to the satellites.
I am really puzzled about this and wonder if others have similar experience with nest cams? I would love to hear from nest cam users who don’t have these issue to understand their configuration — Orbi and The cameras.
Thanks,
Manny
Hamstar
Sep 17, 2018Guide
Hello FURRYe38,
Here are the answers to your questions:
- Mfr and model# of the ISP modem: (google) GFR G210 NETWORK + BOX
- Size of your home: 3328 sq.ft. 2 story contemporary
- Distance between router and satellites: 20 ft to rear satellite; 25 ft to front satelite. Router in approximate middle of house on first floor; each satellite on second floor
- Wi-fi channels: 2.4GHz = 11; 5 GHz = 48
- Neighbors near by: yes - see NetSpot screenshot attachment
- Wireless Settings: Mimo (enabled), Daisy Chaining (enabled), Fast Roaming (disabled), IPv6 (disabled)
- will try disabling mimo and daisy chaining and observe before trying next changes
- 2.4 GHz settings: CTS/RTS Threshold = 2347 Preamble mode = automatic and 20/40 MHz Coexistence is checked
- 5 GHz settings: CTS/RTS Threshold = 2347 Preamble mode = automatic WMM is enabled
- If disabling mimo and daisy chaining are not successful after some observation, I will perform the additional changes suggested:
Thank you,
Manny
- HamstarSep 17, 2018Guide
Forgot to upload the netspot screenshot. here it is. Also, I have Beam Forming on (per NG tech support)
