Hamstar
Sep 17, 2018Guide
Nest camera drops still frequent on Orbi RB50 firmware v2.1.4.16
I have had my Orbi system for about 3 months, purchased from Costco in June. 1 day after installing the system, firmware was upgraded to v2.1.4.16. I have google fiber 1000 and enjoy the speed. Me o...
- May 24, 2019
My Nest was frequently going offline. I changed my settings on my Orbi to match Kickworms settings and I have not had a drop in over a week. Seems resolved now. Here are the settings from Kickworms post:
- 20/40 MHz Coexistence is enabled (2.4GHz)
- WMM is enabled (both 2.4GHz and 5GHz)
- CTS/RTS Threshold is 2347 (both 2.4GHz and 5GHz)
- Preamble Mode is Automatic (both 2.4GHz and 5GHz)
- Transmit Power is 100% (both 2.4GHz and 5GHz)
- Daisy-Chain Topology is DISABLED
- Beamforming is enabled
- MU-MIMO is enabled
- Fast Roaming is DISABLED
- 2.4GHz channel is set to Auto
- 5GHz channel is set to 48
- Security Option is set to only WPA2-PSK
Hamstar
Sep 17, 2018Guide
Hello FURRYe38,
Here are the answers to your questions:
- Mfr and model# of the ISP modem: (google) GFR G210 NETWORK + BOX
- Size of your home: 3328 sq.ft. 2 story contemporary
- Distance between router and satellites: 20 ft to rear satellite; 25 ft to front satelite. Router in approximate middle of house on first floor; each satellite on second floor
- Wi-fi channels: 2.4GHz = 11; 5 GHz = 48
- Neighbors near by: yes - see NetSpot screenshot attachment
- Wireless Settings: Mimo (enabled), Daisy Chaining (enabled), Fast Roaming (disabled), IPv6 (disabled)
- will try disabling mimo and daisy chaining and observe before trying next changes
- 2.4 GHz settings: CTS/RTS Threshold = 2347 Preamble mode = automatic and 20/40 MHz Coexistence is checked
- 5 GHz settings: CTS/RTS Threshold = 2347 Preamble mode = automatic WMM is enabled
- If disabling mimo and daisy chaining are not successful after some observation, I will perform the additional changes suggested:
Thank you,
Manny
Hamstar
Sep 17, 2018Guide
Forgot to upload the netspot screenshot. here it is. Also, I have Beam Forming on (per NG tech support)
