SteveLivingston
Jan 20, 2021Guide
Nest camera drops
Is there a stable firmware & settings for using the ORBI RBR50/RBS50 with the indoor Nest Camera in the UK? Symptoms: Camera streams for a period of time then either (a) feed drops entirely, (b) ...
CrimpOn
Jan 20, 2021Guru - Experienced User
SteveLivingston wrote:Is there a stable firmware & settings for using the ORBI RBR50/RBS50 with the indoor Nest Camera in the UK?
Symptoms: Camera streams for a period of time then either (a) feed drops entirely, (b) video stream freezer with audio still live, or (c) video frozen with no sound. Happens through Google Home/Nest App/Nest website across Android Mobiles/Nest Max Hub/Windows PCs. Sick of that blue spinning ring.
The Nest Camera is the only WiFi device having problems?
One step people commonly take is to connect the camera to a different WiFi source. For example, do you have a smartphone that can create a Hot Spot?
Is the WiFi router that was replaced by Orbi still available? It could be plugged in temporarily with the same SSID/password as the Orbi.
I did not see mention of moving the Nest camera to different locations. (Maybe I missed it, sorry).
