SteveLivingston
Jan 21, 2021Guide
Nest camera drops
Is there a stable firmware & settings for using the ORBI RBR50/RBS50 with the indoor Nest Camera in the UK? Symptoms: Camera streams for a period of time then either (a) feed drops entirely, (b) ...
vajim
Jan 21, 2021Master
SteveLivingston
Jan 21, 2021Guide
Only the Nest Camera has issues.
Going to try the following tomorrow and see what happens.
1) See if FW update available on the Nest Camera
2) Use a non-Orbi Router [Which is some bog standard piece of rubbish supplied by Hyperoptic]
3) Run RBR only [Not a long term solution]
4) RBR and RBS both on... But shift the two as far apart as physically possible.
Will let you know how I get on.
From searching forums here it doesn't feel like I'm the 1st person to have Netgear-Nest issues.
- FURRYe38Jan 21, 2021Guru - Experienced User
Let us know how it goes.
- SteveLivingstonJan 22, 2021Guide
Going to get on to Nest customer services. Issues persisted with the non-Orbi router.
Thanks for help so far... hopefully they send out a new cam which doesn't suffer the same problem.
