SteveLivingston
Jan 21, 2021Guide
Nest camera drops
Is there a stable firmware & settings for using the ORBI RBR50/RBS50 with the indoor Nest Camera in the UK? Symptoms: Camera streams for a period of time then either (a) feed drops entirely, (b) ...
SteveLivingston
Jan 22, 2021Guide
Going to get on to Nest customer services. Issues persisted with the non-Orbi router.
Thanks for help so far... hopefully they send out a new cam which doesn't suffer the same problem.
- vajimJan 23, 2021Master
SteveLivingston wrote:Going to get on to Nest customer services. Issues persisted with the non-Orbi router.
Thanks for the update
please share with us what you find out.
- SteveLivingstonJan 29, 2021GuideNew camera sorted the issue. Streams pretty perfectly now.
- vajimJan 29, 2021Master
New camera sorted the issue. Streams pretty perfectly now.Thanks
Issue resolved?
