SteveLivingston
Jan 21, 2021Guide
Nest camera drops
Is there a stable firmware & settings for using the ORBI RBR50/RBS50 with the indoor Nest Camera in the UK? Symptoms: Camera streams for a period of time then either (a) feed drops entirely, (b) ...
vajim
Jan 23, 2021Master
SteveLivingston wrote:Going to get on to Nest customer services. Issues persisted with the non-Orbi router.
Thanks for help so far... hopefully they send out a new cam which doesn't suffer the same problem.
Thanks for the update
please share with us what you find out.
SteveLivingston
Jan 29, 2021Guide
New camera sorted the issue. Streams pretty perfectly now.
- vajimJan 29, 2021Master
New camera sorted the issue. Streams pretty perfectly now.Thanks
Issue resolved?
