jonandmarkuk
Sep 13, 2018Initiate
Nest Protect Battery
Is anyone else having issues with getting a Nest Protect battery to stay connected to the Orbi?
My Nest protect had been working fine for months with my previous Wifi setup (though never updated i...
Sep 13, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
I would contact NEST support as well and ask for there help and information.
