Anonymous
Jan 27, 2018Nest Thermostat with Orbi - Unable to Connect
Hi, I have two Nest thermostats that refuse to connect to my Orbi. I spoke with Nest tech support and they said that this is a known issue and that I need to enable ports 80, 443, 9443, 9543. How do ...
- AnonymousJan 29, 2018
It's working! Odd, but after I put the Orbi in AP mode and completely disconnected from the Internet (whoops), I reset the Orbi to get back to square one and after setting it up I noticed that the Nest downstairs was connected. I went upstairs and tried to connect the other Nest and...it worked! All I did was reset the Orbi after putting it in AP mode in error.
One of my Nest's did have a message that it was last updated on January 24, so maybe that has something to do with it too.
Thanks all!
sfsdfd
Jan 28, 2018Star
I had a second-generation Nest, too. It worked OK, if not great, with the Orbi for about a year, but the 2.1.1.16 upgrade came along and just... totally broke it. I couldn't connect to the network at all.
I rolled back my Orbi to 2.0.0.74 (which had worked OK before) - and yet, the problems did not resolve. The Nest claimed to be able to connect to the network, but I could never get an "app key" via the network to re-add the thermostat to my account.
Get this: When I called Nest tech support, they asked me to check the network config page... where I found that ping value between the Nest and the Orbi was...11,000 ms. That's right: a ping of 11 seconds. The Nest was literally 20 feet away and with unbroken line-of-sight from the Orbi base station.
I have no idea what happened, but it was clear that I wasn't going to be able to reconnect my Nest to the network (or my Nest Protect smoke detectors, which pull their network settings from the thermostat - and hence also could not connect). I ended up buying a new Nest thermostat and connecting it to the network, and that worked fine.
tron1982x, I didn't have to do any port configuration to get the new Nest online - nor did tech support suggest that during my call with them about the old one.
- AnonymousJan 28, 2018
wrote:I had a second-generation Nest, too. It worked OK, if not great, with the Orbi for about a year, but the 2.1.1.16 upgrade came along and just... totally broke it. I couldn't connect to the network at all.
Thank you for this response, it's much appreciated. Man, I don't know what to do now.
