Retired_Member's avatar
Retired_Member
Jan 27, 2018
Nest Thermostat with Orbi - Unable to Connect
Hi, I have two Nest thermostats that refuse to connect to my Orbi. I spoke with Nest tech support and they said that this is a known issue and that I need to enable ports 80, 443, 9443, 9543. How do ...
  • Retired_Member's avatar
    Retired_Member
    Jan 28, 2018
    It's working! Odd, but after I put the Orbi in AP mode and completely disconnected from the Internet (whoops), I reset the Orbi to get back to square one and after setting it up I noticed that the Nest downstairs was connected. I went upstairs and tried to connect the other Nest and...it worked! All I did was reset the Orbi after putting it in AP mode in error.
    One of my Nest's did have a message that it was last updated on January 24, so maybe that has something to do with it too.
    Thanks all!
