stanleyleecm's avatar
stanleyleecm
Nest Thermostat with Orbi
Ever since I installed the RBK50, the nest will not connect to it. Nest can't even find my router to connect to.    Any idea?   Thanks!
  • morrisseysb's avatar
    morrisseysb
    Sep 26, 2017
    Well maybe it is dead.  One of my nest protects the wifi failed and they replaced it.  Thats why iwould try tech support they may just send you a new one.
