dalewebb
Dec 05, 2019Aspirant
Nest X Yale lock disconnects
Orbi RBR40 plus 2 satellites Have many Nest products including thermostat, Nest Protects, Nest Hello, and a Nest X Yale lock. The Nest x Yale lock keeps dropping it's connection (maybe other device...
- Dec 06, 2019
Thank you for all your help. I think I have my modem bridged and the PPPoE set up on the router. Things appear to be working fine.
Thanks again.
Dec 05, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
