dalewebb
Dec 05, 2019Aspirant
Nest X Yale lock disconnects
Orbi RBR40 plus 2 satellites Have many Nest products including thermostat, Nest Protects, Nest Hello, and a Nest X Yale lock. The Nest x Yale lock keeps dropping it's connection (maybe other device...
- Dec 06, 2019
Thank you for all your help. I think I have my modem bridged and the PPPoE set up on the router. Things appear to be working fine.
Thanks again.
CrimpOn
Dec 05, 2019Guru - Experienced User
dalewebb wrote:The Nest x Yale lock keeps dropping it's connection
"Dropping its connection" can mean different things:
- The device disappears from the Orbi "Attached Devices" display.
- The app that controls the device stops functioning.
Is it correct to assume that the lock appeared to install correctly and operated successfully for a period of time?
How does the lock get reconnected?
Thanks
