dalewebb
Dec 05, 2019Aspirant
Nest X Yale lock disconnects
Orbi RBR40 plus 2 satellites Have many Nest products including thermostat, Nest Protects, Nest Hello, and a Nest X Yale lock. The Nest x Yale lock keeps dropping it's connection (maybe other device...
- Dec 06, 2019
Thank you for all your help. I think I have my modem bridged and the PPPoE set up on the router. Things appear to be working fine.
Thanks again.
dalewebb
I'll try and answer all your questions:
| Model Name | Device Name | Current Version | Status | |
| Router | RBR40 | RBR40 | V2.3.5.30 | No new firmware version available. |
| Satellite | RBW30 | Orbi Satellite-1 | V2.3.5.6 | No new firmware version available. |
| Satellite | RBW30 | Orbi Satellite-2 | V2.3.0.4 | No new firmware version available. |
Zyxel C3000Z
What is the size of your home? Sq Ft? What is the distance between the router and satellite(s)?
About 1200 sq ft. Modem and router are in the basement. Satellite 1 is almost directly above the modem/router in the upstairs. Satellite 2 is about 20 feet from satellite 1.
What channels are you using?
2.4 Ghz: 11
5 Ghz: 48
My phone "sees" about 4 wifi networks. Most are quite weak.
Is it correct to assume that the lock appeared to install correctly and operated successfully for a period of time?
Lock has operated successfully for up to a month, then will go offline (Nest app tells me it is offline. Guess I don't know exactly what that means.) Nest tech support tells me the LOCK is offline. The Nest Connect is working nominally.
How does the lock get reconnected?
Occasionally, it just seems to reconnect without intervention. Usually, I have to remove the batteries for a time and then put them back in to reconnect.
I'll try the suggested changes in your list.
Thank you.
Dale Webb
- CrimpOnDec 05, 2019Guru - Experienced User
2.3.5.6 shows as the current firmware for the RBW30. Might be worth a few minutes to download the firmware from the support site:
https://www.netgear.com/support/product/RBW30.aspx#RBW30%20Firmware%20Version%202.3.5.6
Unzip the file, navigate to the satellite web page, and then do a manual firmware update.
What does the Attached Devices display show the lock connected to? (router, satellite1, satellite2)
- FURRYe38Dec 06, 2019Guru - Experienced User
dalewebb wrote:
What is the Mfr and model# of the ISP modem the NG router is connected too?Zyxel C3000Z
This has a built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the size of your home? Sq Ft? What is the distance between the router and satellite(s)?
The distance between the RBWs and RBR is too close. This is probably causing too much wifi signal over lap between these devcies. 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- dalewebbDec 06, 2019Aspirant
I called Centurylink to configure my modem (Zyxel C3000Z) to bridging mode and all he had me do was switch the WAN settings from the current PPPoE setting to Transparent Bridging. My internet went away. He said now, I needed to contact Netgear to configure the router. Is there an article somewhere to configure the Orbi router?
Check the user manual for Orbi
If your using PPPoE, you'll need the account login and PW for your PPPoE account with your ISP.
