dalewebb
Dec 05, 2019Aspirant
Nest X Yale lock disconnects
Orbi RBR40 plus 2 satellites Have many Nest products including thermostat, Nest Protects, Nest Hello, and a Nest X Yale lock. The Nest x Yale lock keeps dropping it's connection (maybe other device...
- Dec 06, 2019
Thank you for all your help. I think I have my modem bridged and the PPPoE set up on the router. Things appear to be working fine.
Thanks again.
dalewebb
I'll try and answer all your questions:
| Model Name | Device Name | Current Version | Status | |
| Router | RBR40 | RBR40 | V2.3.5.30 | No new firmware version available. |
| Satellite | RBW30 | Orbi Satellite-1 | V2.3.5.6 | No new firmware version available. |
| Satellite | RBW30 | Orbi Satellite-2 | V2.3.0.4 | No new firmware version available. |
Zyxel C3000Z
What is the size of your home? Sq Ft? What is the distance between the router and satellite(s)?
About 1200 sq ft. Modem and router are in the basement. Satellite 1 is almost directly above the modem/router in the upstairs. Satellite 2 is about 20 feet from satellite 1.
What channels are you using?
2.4 Ghz: 11
5 Ghz: 48
My phone "sees" about 4 wifi networks. Most are quite weak.
Is it correct to assume that the lock appeared to install correctly and operated successfully for a period of time?
Lock has operated successfully for up to a month, then will go offline (Nest app tells me it is offline. Guess I don't know exactly what that means.) Nest tech support tells me the LOCK is offline. The Nest Connect is working nominally.
How does the lock get reconnected?
Occasionally, it just seems to reconnect without intervention. Usually, I have to remove the batteries for a time and then put them back in to reconnect.
I'll try the suggested changes in your list.
Thank you.
Dale Webb
CrimpOn
Dec 05, 2019Guru - Experienced User
2.3.5.6 shows as the current firmware for the RBW30. Might be worth a few minutes to download the firmware from the support site:
https://www.netgear.com/support/product/RBW30.aspx#RBW30%20Firmware%20Version%202.3.5.6
Unzip the file, navigate to the satellite web page, and then do a manual firmware update.
What does the Attached Devices display show the lock connected to? (router, satellite1, satellite2)
