ARoesberry
Apr 24, 2020Follower
Netfear Orbi RBR20
Over the last week our family has had to reset our Orbi RBR20 router at least once a day, as the signal goes out several times a week. Today (4/24/20) ot reset once and then lost all connectivity to t...
Apr 24, 2020Guru - Experienced User
What Firmware version is currently loaded? v16 is most current...
