carlos45
Aug 21, 2020Aspirant
Netflix / Amazon Prime not connecting
We have recently reconfigured our router / modem set up with orbi system acting as a router and the nighthawk set to modem only. This has worked perfectly for the last few weeks We however just reali...
- Aug 21, 2020
What FW is currently loaded?
Is Armor or Circle or IPv6 enabled on the RBR? Try disabling these 3 and see if this changes anything.
Has a factory reset and setup from scratch been performed since last update?
If your on a DSL ISP service, try setting the MTU value to 1472 or 1492 for DSL ISP services.
Aug 21, 2020Guru - Experienced User
