Mdoherty770
Jun 14, 2019Aspirant
Netflix and Prime will not connect
Cannot connect to Netflix and Amazon Prime movies Reset router and satelite, still having issues Not an expert, only follow what is in instructions Need help,
- Aug 25, 2019I fixed it by using web browser to manage. It automatically prompted me that it will change up to 10.0.0.1
I also fixed timezones problem it was on Lima Peru time. Fixed to my timezones.
Everything works.
It was blocking http sites international ones and no apple appbdownload or Amazon.
This started when I changed my Verizon modem and I now realized when I did I hadn't fix the setting on Verizon router like I did when I first set up orbi. But now orbi does it for you.
Jun 15, 2019Guru - Experienced User
- Mdoherty770Jun 16, 2019Aspirant
It was provied by AT&T U-verse
Model number 5268AC-FXN
Pace may be the manufacturer
- FURRYe38Jun 18, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Mdoherty770 wrote:It was provied by AT&T U-verse
- gr8shoJun 18, 2019VirtuosoWhen you logon to Orbi via browser, use 10.0.0.1. Att routers use the same subnet as Netgear. Orbi will move itself to resolve the conflict. This should also clear up the access issue.
Also as was mentioned, avoid double NAT. This is accomplished by putting the Att gateway into DMZ+ mode. A new firmware update presumably resolved a severe performance issue, so check for that.- Robfed135Aug 25, 2019AspirantI fixed it by using web browser to manage. It automatically prompted me that it will change up to 10.0.0.1
Everything works.
