Mdoherty770
Jun 14, 2019Aspirant
Netflix and Prime will not connect
Cannot connect to Netflix and Amazon Prime movies Reset router and satelite, still having issues Not an expert, only follow what is in instructions Need help,
- Aug 26, 2019I fixed it by using web browser to manage. It automatically prompted me that it will change up to 10.0.0.1
I also fixed timezones problem it was on Lima Peru time. Fixed to my timezones.
Everything works.
It was blocking http sites international ones and no apple appbdownload or Amazon.
This started when I changed my Verizon modem and I now realized when I did I hadn't fix the setting on Verizon router like I did when I first set up orbi. But now orbi does it for you.
Mdoherty770
Jun 16, 2019Aspirant
It was provied by AT&T U-verse
Model number 5268AC-FXN
Pace may be the manufacturer
Jun 18, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Mdoherty770 wrote:It was provied by AT&T U-verse
