Thandungen
Feb 25, 2020Aspirant
Netflix And Spectrum streaming on Roku
I updated the firmware to V2.5.1.8 a few weeks ago and I have had issues with Netflix and Spectrum streaming on all our Roku devices ever since. I notices there are some Reddit discussions about the s...
Feb 25, 2020Guru - Experienced User
You don't have Armor enabled do you on the RBR? If you do, please disable it. Been others posting about Armor causing problems.
A factory reset maybe needed as well with the RBR and setup from scratch.
Thandungen
I don’t have Armor enabled. Out of the two dozen or so streaming apps installed Netflix and Spectrum are the only ones having issues. Never had an issue with Netflix before the update. Will try a factory reset but then won’t the firmware update bring it back to the same point?
- FURRYe38Feb 25, 2020Guru - Experienced User
No, this only clears any configurations that maybe causing problems. Try the reset and let us know.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- ThandungenFeb 25, 2020Aspirant
Thank you very much. I will try these and get back to you. Appreciate your time.
:smileywink:
