FranToledano
Jul 09, 2018Aspirant
Netflix inaccesible desde Apple 4K
Hello everyone. Strange behavior in this structure. Internet access through ont and router of the operator. Router netgear orbi behind the router of the operator to give wifi coverage to the entir...
- Jul 10, 2018
RESOLVED.
Wan configuration. NAT filter -> open
with this, netflix on all apple's tv works fine.
FranToledano
Jul 10, 2018Aspirant
Thanks for the asnwer.
I've got independent equipment.
One ONT Nokia and one router Sagecom H500-S from my carrier.
If I connect the Orbi to the Nokia ONT (no router from Vodafone), Obit conects perfectly to the Net, but apple tv netflix app, lost access.
All other internet services and access works correctly from any pc, tablet, celullar, etc..
If I access netflix from a tablet or pc, it access corrtecly.
Only netflix app on apple's tv(one 4th generation and on 4K) lost connection (hbo, youtube,amazon prime, etc,.. connects ok).
If I put another time the Vodafone router besides ont and Orbi router, apple tv netflix app gain access correctly.
If I connect behind a dmz, I will have a nat besides a nat (double nat) and there is not the optimal configuration (ping, etc ..)
If I configure a Orbit as an AP, is loosing the router power of netgear, nor?
Any other ideas?
King regards.
Jul 10, 2018Guru - Experienced User
Please try using the DMZ. This will help with NAT issue which you seem to be currently in since the Sagecom seems to have a router built in I think. DMZ will be good for this if your ONT can't be bridged.
You can run the Orbi in AP mode as well however if you already have a router the line, then AP mode would be another solution since it's not good to have two routers on the same line. So try the DMZ suggestion or AP mode on the Orbi router.
- FranToledanoJul 10, 2018Aspirant
There isn't best solutions.
More test.
Apple tv with fixed ip.
If I put in netgear Orbi DMZ the ip of the apple tv, netflix in this apple tv works fine.
I firmless think there is something in the configuration of the Orbi that blocks netflix access.
Netflix client service tells me that his apps don't use ports that must be open.
Any ideas???
Thx.
- FURRYe38Jul 10, 2018Guru - Experienced User
I would try using the modems/ONTs DMZ for the Orbi.
RESOLVED.
