Leonhaddrell's avatar
Leonhaddrell
Follower
Aug 20, 2019
Netflix not working with new orbi AC2200
Hi guys can anyone tell me how to fix netflix not working as with all my other streaming services?
  • plemans's avatar
    Are you saying none of your streaming services are working?
    Is it only certain devices or all devices?
    Is the RBR20 a new setup?
    What firmware is on it?
    What modem are you using?
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
