alterndog
Feb 06, 2020Follower
Netflix Orbi issues
I have an Orbi RBR50. We switched to a Fiber Optics provider and since then netflix continues to buffer and have lower quality. I talked to the service provider and they don't see any issue on their ...
Feb 06, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Might update FW to v2.5.1.8 later on.
