alterndog
Feb 06, 2020Follower
Netflix Orbi issues
I have an Orbi RBR50. We switched to a Fiber Optics provider and since then netflix continues to buffer and have lower quality. I talked to the service provider and they don't see any issue on their ...
Narcissus
Feb 06, 2020Aspirant
I have the samme problem after switching til fiber my Netflixapp on my LG B6 keeps loosing connection and buffers. When I use my Chromecast 4K there is no problems with the Netflix streame. All other apps on the tv are woorking fine.
I am on V. 2.5.1.8 on my RBR50 with 2 sattelits. Sadly I have not found a solution yet....
- FURRYe38Feb 06, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance? Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerTry using the netflix app with the RBS's turned off.
What devices do you have the netflix app installed on?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last update?
