rogernation
Nov 09, 2018Follower
Netflix won't connect via ATT router
OK, hope you guys can help. I just hooked up my new Orbi and everything is runnuning great except Netflix. I try ro access Netflix via Dish Network. I have my Orbi connected to ATT Router/Modem 5268A...
Nov 09, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Be sure that the Orbi and ATT modem are not using same IP address of 192.168.1.1. If you walk thru the setup wizard on the Orbi it should help with this if your going to use the modem in router mode. Review the options...
